Offline playlist solution?
So, i am thinking recently… the reason that they removed the online playlists on iOS is because that it would be possible to download movies and TV shows without paying, right? Maybe brave can try to modify the code to where it can make a exception for things that need to be paid? Then apple will have absolutely no reason to remove offline downloads, and possibly return them if plan A does not work.
