NOTICE: Unexplained Data Loss Issue
@jbrock11 I think each of these files will save a .bad if they get corrupted. If you’re not getting one specifically for Local State then the problem is something different for sure
The passwords are still saved and there, but access to them is restricted, you can still find them all using WebBrowserPassView
This happened to me this Thursday pm. I checked on my other browser sessions from the sync and my passwords vanished everywhere.
Android, macOs and on Windows.
This was my main pwd vault, didn’t had any backup and there’s lots I know I won’t be able to get back as it was with an older e-mail I don’t have access to anymore.
Brave crashed. History is there, All Tabs opened OK but ALL passwords have vanished.
I faced this problem on 24/07/2023 after the restarting the device. All Data got deleted except cookies and both Search and Watch history. Here’s the answer to all your questions:
Basic Data To Gather:
1) * What OS are you using where the issue occurred (be as specific as possible, eg Win 10, Win 11, macOS Ventura v13.3.1)?
Ans→ Windows 10 Professional 64bit
2) What Brave version you have installed (you can view this by opening the browser and going to About Brave)
Ans→ Version 1.56.11 Chromium: 115.0.5790.102 (Official Build) (64-bit)
3) * When/how/what actions were taken when the data loss occurred (eg, Did the browser crash? Did this occur after a system restart? Did this occur after an update? etc.)
Ans→ Well I only remember Shutting Down my PC and after some few hours, the data was gone, what saw was the previous unclosed tabs were still open but a new tab with welcome to brave message was present. Not sure about that the problem occur due to an update or not.
4) If the issue did occur after a crash, providing us with the crash report ID would be helpful (you can do this by going to brave://crashes and sharing the crash report ID left under the event)
Ans→ It definitely wasn’t a crash as i checked crashes section, the latest one was around May 28th. And Right now it’s July 24th.
5) * Please tell us exactly what data was lost (was it just passwords? Passwords and bookmarks? All data? etc.).
Ans→ All Data was lost except Cookies and History.
6) Are you using a password manager extension? If so, is Offer to save passwords enabled?
Ans→ I was using password manager with offer to save password turned “ON”.
7) Are you using Brave Sync?
Ans→ No I was not using Brave Sync.
Advanced data to gather:
1) * Histograms information can be very helpful for us — you can find this information by going to brave://histograms/OSCrypt and clicking the Download button. If you have these data, please simply say (in your reply) “I have histograms to share” and I will DM you so that they can be sent securely.
Ans→ Yes I have histograms to share but the problem is the recorded sample is only just 1. If you still want it please tell me where to DM it.
2) * It can be very helpful to know whether or not Login data (where passwords and login data are stored) still holds your information information and it simply isn’t being decrypted, or if it’s just blank and the data has been fully cleared. Note that the Login data file is an SQLite file and requires a SQLite DB viewer to view properly. If you do not have one, I would recommend this one as it is free and easy to use. To check if your data is present:
Ans→ Nope it’s gone from there all tables index are empty.
Hope it answers all questions dev. I also hope that you guys could fix it.
Same problem as everyone else here, passwords gone on Brave Browser itself. I’m running it on Windows 10, browser version 1.56.14 and I have never used sync anything. Have yet to try downloading older version but thought I should at least put down what I found before doing so. Keep in mind, I don’t touch anything I don’t understand, so it is a rule that until I do understand it, I do not make nor do I save changes.
Under “AppData > Local > BraveSoftware > Brave-Browser > User Data > Default”, there is a file called “Login Data” which does contain the encrypted passwords. From what I understand (which could easily be incorrect) Brave takes your passwords and encrypts them using your machine’s system key (or something similar that is specific to your device) and then saves said key in the file “Local State” under AppData > […] > User Data.
I am notorious for never updating anything but certain things update on their own such as Windows and Brave, apparently–I have never clicked the ‘update’ button on either. Recently, in trying to solve this problem, I’ve downloaded the DuckDuckGo browser for about four minutes and all it told me is that it located the passwords in my machine but was unable to decrypt them. Since then I have contacted a friend who was willing to attempt to fix this with me for about six hours straight one Saturday not that long ago.
I also searched around and before using python we looked into this blog (https://www.alertra.com/blog/decrypting-browser-passwords-other-secrets) and this github page (https://github.com/kdirectorate/browserscan) but unfortunately we both got varying error messages similar to this one:
Error that I don't understand
Error Status 0xc000000d is apparently “Your PC Needs Repair” which means that the computer is apparently unbootable - which clearly is not true. When running the .exe file inside its own file path, I got an error with “_MEI188442” while running the .exe file inside of “C:\Users[my user name]\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default” got me an error with “_MEI200962” as shown in the picture. I don’t know the significance of the change, but I will note that I do not have files _MEI188… nor _MEI200… and neither does my friend’s computer when he attempted to run it outside of Python. My friend, for context, does use Brave but is not having this issue whatsoever despite using the same version on a similar Windows 10 non-sync device.
Maybe the program just does not work outside of Python, so we ran it in Python. Long, long story short, it could not decrypt the passwords. Technically, it did decrypt them but the remaining string of characters didn’t make any sense and it kept finding one character or so that was ‘not decrypting properly’, so either it didn’t work or, somehow, my system key has been changed without my input - can that happen?
I also found this (https://github.com/moonD4rk/HackBrowserData) and before you go downloading this one, my virus protection whatever tagged this as a trojan and I don’t really believe it is one; so instead I downloaded this (https://sandboxie-plus.com/) and tried to download and run the former in Sandbox. It worked, but I got an error saying that it was unable to run. Maybe the program doesn’t work or maybe it cannot work while inside Sandbox, but due to my limited knowledge, I’d prefer if someone else with far more understanding take a look at it first. Sadly, my friend, not having this issue, is unwilling to take time out of a busy day to look into it which I completely understand but it is also rather frustrating not having your passwords such as this entirely new Community Brave account because the old one’s password is also missing.
I will attempt to download a previous version of Brave at a later date and if it works, I’ll post an update. If not, I don’t know, I’m kinda loss as it is.
Microsoft Windows 10 Pro: v10.0.19045
Brave: 1.57.53 Chromium: 116.0.5845.114 (Official Build) (64-bit)
Crash report ID: 030c0f92-3724-4869-9e10-f50d3d4975a5 (I don’t have auto-sending enabled, so manually sent this just before this post)
Brave crashed while not in use, I believe it was actually the entire chromium stack that fell over as I had multiple apps (all chromium backed (pretty sure, not 100%)- Brave, Discord, Signal) all crash at once, except Brave was the only one to lose any data.
Brave had an update downloaded / pending that I had not restarted it for at the time, upon the browser re-starting (and the updated version being used) the menu note that usually shows ‘Update’ instead showed ‘Error’ though I wasn’t able to find out what the error was.
The following does not apply:
  • Profile has not been changed (there is only one)
  • Data wasn’t cleared
  • Data isn’t set to clear on exit
  • Windows user/system data has not changed via update, nor has the password been changed.
Missing data:
  • Site Permissions/Preferences (ie sound, camera, microphone, autoplay, notifications, save password etc)
  • Program/User Preferences (Brave settings, show bookmarks bar, start page etc)
  • Extensions and extension data (didn’t have backups, that’s on me, lost probably years of it, whoops – but Brave should STILL make backups itself whenever it does an update or at least give the user the option to enable automating such a thing)
  • Theme (I assume the theme is technically an extension or somesuch OR the default UI just changed drastically, I don’t recall if I had a theme)
  • Rewards (Only the Uphold connection, the actual history/seen ads remains on connecting, but that might be fed back from Uphold upon re-connecting?)
  • SOME active sessions/logins (login data DB has a single entry was a site with an active session after the data loss)
Data retained:
  • Bookmarks
  • History (including Downloads history)
  • Cookies
  • SOME active sessions/logins etc (probably covered by cookies, but wanted to note it explicitly)
  • Probably anything else I haven’t already mentioned as missing (or I haven’t noticed yet, or it’s a feature I never used to begin with to notice (such as saved passwords))
No password manager, no brave sync.
Login Data database was empty, OSCrypt histogram data appears to be missing (Mine only has a few entries, I assume it should be more)
Hope this helps.
bump for passwords thanks everyone
It’s now been 5 months, is there an update?
hello, an hour ago i got onto my computer which has been on all night and i open brave to see all my data-history, modules, bookmarks, save passwords are all gone. I cant believe this its so infuriating is there any possibility to roll back or retrieve my old state of brave from like 24 hours ago? i dont understand how this can happen.
@Mattches @clifton do we have any additional information after everything shared by people? I’m still seeing this as something being reported by people. For example, a possibility of Just got onto my computer and all my data on brave is gone, history passwords EVERYTHING
Lost all my passwords again today after a failed launch and crash. I think it was trying to apply an update, but just locked up. When I relaunched all of my settings were default and my pw data was gone. Happens every 4 or 5 months now ever since auto update was made mandatory and no option is available to backup your data before it crashes on the update.
Just to add to my last post, my Login Data file exists under User Data\Default and has all of my previously stored accounts, but in Settings it says I have no passwords stored and its a clean slate. Maybe something happening during update where it can no longer read or decrypt the password data that is there, or is creating another profile on its own. Not sure.
I’m running Brave on several devices, all Android and Windows based, but my desktop is running Windows 11 Home, version 22H, Build 22621.228 with the Windows Features Experience Pack installed. All devices are synced to the Desktop. I keep the OS current and I’m running in 64-bit mode. Brave is at Version 1.58.235 Chromium 117.0.5938.140 and is also running in 64-bit mode.
Every time I “Update” Brave to a new version all my passwords and stored login data are cleared along with all my autofill data. This happens regard EVERY TIME I do a new update which is very annoying. I using only 1, the initial default Profile which I renamed.
This happens every time I “Update” without fail. Under my Privacy and security settings I DO NOT have the boxes checked to clear browsing data for these settings either.
I wanted my stored data to remain unchained after an update.
None
OS: Windows 10 Pro
Browser: Brave - Version 1.58.137 Chromium: 117.0.5938.153 (Official Build) (64-bit)
I also had the exact same issue last week. While using the browser, it suddenly crashed, and when I reopened it, all the settings, history, and passwords were gone. However, when I checked the %AppData% directory, everything was still there. I tried downgrading the browser, but it kept auto-upgrading to the latest version. I now have about 70 profiles, and it has become unusable. I don’t want to set up the whole thing again, so for the time being, I am switching to Firefox Multi-Account Container. I hope the issue will be fixed soon.
@hunsinge which way are you updating? I mean, is it through auto update or you grabbing it from somewhere?
History and all disappear as well or does it remain?
Ignoring the idea of renaming the profile, have you changed any of the core files? What I mean is some people will add, remove, or edit content within Program Files or other locations within Brave’s core. Then when Brave updates, it applies based on where it should be. So if you’re (using “you” loosely, meaning if anyone) modifying any of the folders or locations, this could result in issues as you have explained.
I lost all my passwords in an automatic update. I see this issue has been addressed in the ‘Brave Community’ a number of times, but evidently it has not been remedied.
Why didn’t Brave management give users a heads up that such a flaw existed? What happened here, Brave?
And as I saw in some of the answer threads, advising us to build a backup password file after they are lost isn’t helpful at all.
I used Brave exclusively. I had been quite happy with it. But now I am digging out passwords from years ago, and I’m sure I’ll be at this for quite some time. I can’t take the risk of this happening again. So my question to the Brave Community is: What is another secure browser to use?
@Mattches @clifton @sampson Just wanted to tag the three of you to see if anyone has further updates. Also want to point out that I just merged over a couple topics here from people who have recently experienced issues of lost data during updates.
I’m using the update button from within the browser. Yes, all my history and everyone is gone as well although I do have the browser set to clear this on a restart. re: your final question I have made no changes to the core files. Brave is installed as it is defaulted, no location, content, or file changes.
FYI I’ve been experiencing this issue for over a year but finally get fed up with it and decided to post here hence my post that got merged over the weekend into this posting.
