Yes! I can connected to Uphold.
Thanks!
Thanks!
@HFraan,
You’re very welcome, thank you for confirming.
Yes, It got connected few hours ago thanks a lot for great help. Can you please tell if we will be paid this month or not
@proxynotavailable,
Yes – this issue should have no effect on your payout.
Thanks for keeping us updated @Mattches ! All seems to be fine for this guy too.
Was the issue fixed? I still can’t login.
@hosayam827,
This issue is not related to your ability to login to your account. If you’re having an issue logging into your account, please start a DM with me and @steeven and we will try to assist you.
@Mattches
For me the issue still exist. I have to reconnect every day.
Reconnecting is flawless but next day i have to do it again.
i have the same reconnecting issue.
@steeven the same here
Any news on this front?
On Uphold I see “Brave Browser” and “Brave Rewards” under Authorized Applications. Also there’s cards for each of the site I added. So it seems normal on their end.
Edit: after reconnecting Uphold, the same issue just reoccurs the next day.
Of course its not these sites fault, they are ok; all this mess is sole Brave fault.
not yet…must wait
I didn’t have this problem last month. But, now in November, I’m getting the same warning: “We are having trouble communicating with Uphold. Try reconnecting.” I followed some tips from the community and nothing has changed, the problem persists. What should I do?
Same issue with me I have try but nothing done.
For me, it seems the link to uphold/dashboard in “continue to verify” crashed.
Trying to connect out from here in a new browser-tap. Site is open shortly, but then open the normal login-site from uphold (https://wallet.uphold.com/login)
