Not displaying images on Discord
Brave will not display images on Discord
  1. Launch Brave
  2. Go to Discord
  3. Go to a channel, the images (jpg, gif etc) most of the times will not apear
    When using Firefox, Chrome or Dissenter there is no problem
Expected Result:
The image should have appeared
Always
Brave release -1.48.167 Chromium: 110.0.5481.104
Yes
Additional information:
W10 Pro 21H2
Hello @lfbmoreira22
Thank you for reaching us and I’m sorry to hear you are going through this. Could you kindly use guest mode to see if the issue persist? Additionally, please try disabling all shields to see if that solves the issue.
Let us know if that helps!
Hello,
Hello, Guest mode or disabling shields did not work, but I’ve noticed that on while the images were not loading if I do Ctrl+F5, when the page reloads the images are shown.
Thanks.
Turn off “use graphics acceleration when available” in settings
This has happened to me before, and luckily they usually fix it within a week, so make sure to turn it back on every now and then if it causes issues.
I had similar issue with specific sites, news pages mostly. By adding the site URL’s to Settings: Allowed to show images it resolved the issue right away. Inconvenient but its a small number of sites were affected
