Nope. Still no solution to wildly jumping bookmarks.
I have posted about uncontrollably jumping bookmarks in Brave before, but sadly there seems to be no solution to this. AI generated answers and suggestions doesn´t help either.
Now, this is very annoying and time consuming to deal with, and it’s sad because Brave was the best browser until this bug came some three months ago.
It’s the same whether I use win 10, win 11 or Linux.
Wish somebody at Brave would like to take a look at this.
Best regards/
Alex63
To me this sounds potentially like the work of an extension you have installed. On my end, on macOS, Linux and Win11 I do not see the behavior you describe.
If you could share a shot screen recording of the behavior you’re seeing it would be very helpful.
Hi,
Thanks for the reply. I have now made a short film (10 mb) on the problem I have. Where can I send it?
Alex63
You should be able to upload it here on the site or you can upload it to somewhere like imgur and share the link here.
Thanks, I’ve got huge problems with converting my film from .wmv to a .mp4 file…This might take a while…
I believe imgur accepts wmv files if you don’t want to go through the hassle of converting it.
Oh shoot… “Sorry, new users can´t post files” was what I got when I finally succeeded in converting the film to .mp4…
Sorry about that – I made the change on my end and you should now be able to upload it.
Nope, no cigar… still the same message.
Apologies – try one more time for me.
Yes! Success! Hope you can understand what happens on the screen, the resolution is not the best.
It looks very similar to this issue which was opened a while ago:
Can you please confirm the browser version you’re using at this time?
Hi,
Thanks for your reply.
My browser version is 1.80.120
@Alex63 curious to know if you see the same behavior if you try to scroll down/view bookmarks on the brave://bookmarks/ page as well?
No, I don´t. That seems to work fine.
Heyo,
I have not had this problem on my pc nor my phone.
Still no solution to this very annoying bug?
