i need help, i have not audio, it just happens on Brave.
OS: Kubuntu 20.04
Version 1.15.72 Chromium: 86.0.4240.75 (Official Build) (64-bit)
Hello @Carlos_Yoris
make sure that is enabled
brave://settings/content/sound
and is no audio for all website or certain sites?
Hello, thanks for answer.
It is enabled.
I try on every website that i know.
could you go to menu then create a new profile and see if it work or not
and you welcome
I occasionally have this issue, but I do not think it is related to the browser (for me)
In the Plasma (think KDE, running on openSuse Tumbleweed) workspace panel, I click the Volume widget.
Notice I have two devices (HDMI and S/PDIF) - sometimes the “wrong” device is selected (not sure why it changes)
(not saying this is your issue, but might check it).
i was just a dumb problem with my OS
I discard all related to OS because it was happening only on brave but the solution was:
Panel>Volume widget>Applications>Brave volume was blocked.
Eventually i would have found it but you give the idea before. Thanks.
no you are not @Carlos_Yoris
we all miss something sometimes and glad that you figured it out and have a nice day
