No audio in screen recorders (Outplayed/Nvidia) via virtual audio cables since v1.91.168
Since the recent update (v1.91.168 / Chromium 149.0.7827.103), Brave’s audio is completely ignored/not captured by recording software like Overwolf Outplayed and Nvidia Shadowplay when using virtual audio routing (specifically SteelSeries Sonar).
The audio plays fine in the headset, but the recording software captures nothing at all.
Testing done:
Recording Google Chrome with the exact same Sonar routing works perfectly. The issue is strictly isolated to Brave.
Tried changing Windows Volume Mixer outputs, no success.
Tried disabling Hardware Acceleration, no success.
Can you provide:
  • Windows version (10 or 11, build number)
  • Sonar version
  • Whether ShadowPlay is set to Single Track or Separate Tracks
  • Whether OBS Application Audio Capture can capture Brave audio
Thanks!
