No audio in Brave after Steam Link usage
After using Steam Link, Brave browser no longer plays any sound. Brave does not appear in the volume mixer, but headphones and other browsers work fine. Renaming the entire Default folder restores audio, but this also deletes all settings, logins, and extensions, which I want to avoid. I only want to reset the audio settings or the specific corrupted audio files without affecting other data. Preferences file has been checked and does not contain audio entries; deleting it does not fix the problem. The issue likely lies in the “Local State” file or a similar JSON file.
  1. Use Brave normally.
  2. Launch Steam Link (exact sequence may vary).
  3. Afterwards, Brave loses all audio output.
Brave should continue to play audio normally without losing other settings or logins.
Brave Version : V 1.85.118
  • Problem only affects Brave Profle; other apps and browsers or incognito mode in Brave works fine.
  • Issue is resolved temporarily by renaming the Default folder, but this is not an acceptable solution.
  • Goal: Reset only the audio configuration to restore sound while preserving all other data.
@CPP
Maybe some tip at:
‘https://support.google.com/chrome/thread/8079458/chrome-not-using-default-audio-device?hl=en’
Or:
https://www.ifixit.com/Answers/View/419128/I+have+no+sound+in+Chrome.
Maybe “banging on the toggle switches” at:
brave://settings/content/sound
You might create an additional Brave Browser user Profile for test purposes. That would provide a Local State file for comparison?
Okay, I really don’t know why it helped, but apparently,
“Maybe “banging on the toggle switches” at:
brave://settings/content/sound"
in combination with resetting the Windows app Audio worked. It’s working again now, and I’m really glad and very thankful for that! :slight_smile:
