Hello, I am from Nepal. I use brave browser for surfing, but I earn something’s in BAT tokens.
I think I can withdraw this token to uphold. Furthermore, I verified uphold and trying to connect to reward, but I cannot be able to connect. It says that the Region has not supported. I am from Nepal, so I need help from brave support with live
Nepal is not supported to connect Uphold or Gemini.
Brave is trying to add more countries. But it is something that may take long time as it involves compliance with regulations in all affected countries.
Your only option at the moment it keeping accumulating your rewards until a solution is offered. You do not loose much at the moment, we are in a bear market and BAT value is very low.
You can follow regular updates on the development of this in the following post.
e class='quote' data-post="1" data-topic="417552">For new information, check bottom comment. Otherwise can review some of the below to see overall status since July 26, 2022. Brave’s List of Supported Countries OLD UPDATES BELOW: Can’t add more since April 4, 2023. Update: April 4, 2023 Only because it’s been a little while since I gave an update, thought I’d just do a small post. At this point they still have nothing solid to say about adding countries again, the new partner(s) they are hoping to add, or even of an ETA for the sunsetting of v…
