In a bit of a rush, trying to get repaired laptop up to speed (for travel in 19 hours) with the new one used in the meantime. That will be the main one once everything is on there.
I had trouble setting up sync years ago with an old laptop and my phone, and wasn’t sure if it was working or not, and these are likely not the same devices. And how (which takes precedence, how are deletions/edits in one handled, which items are added or revised vs being overwritten?
I’m not sure of the most efficient, best way to do this?
At this point I’d get overwhelmed trying to figure this out, so I much appreciate step-by-steps for those items that are possible. Thanks.
*Description of the issue:
a) How do I “merge” the new bookmarks on laptop 2 with those on laptop 1–Export/import and vice versa, but before I import?
b) How can I get the Tab Groups that I’d set up on #2, to #1?
c) How can I get the open tabs and browing history from #2 to #1?
d) How can I sync the settings, with priority any changed in #2 from default, over those corresponding settings in #1? I think it’s mostly how different sites are handled (Shields off, etc).
up Reproduces how often:
#1 Version 1.77.101 Chromium: 135.0.7049.115 (Official Build) (64-bit)
#2 Brave 1.80.113 Chromium: 138.0.7204.49 (Official Build) (64-bit)
Both are Dell XPS with similar config., sync chain is not set up yet. At some point I’ll add my Android phone.
Laptop 1 Windows 10 Pro
Laptop 2 Windows 11 Pro
