Navigation Toolbar changing place by itself
Description of the issue: The navigation toolbar keeps changing place, even it being set to be at the bottom.
  1. Open Brave on Android device, and go to Settings.
  2. Go to Appearance (under Display section), and activate the option Bottom navigation toolbar.
  3. Go to any YouTube video.
  4. Put the video in full screen, then exit out of full screen again.
At the start, the navigation bar is at the bottom of the screen, but after switching the video to full screen and exiting, the navigation bar moves to the top of the screen, along with the video’s url link.
That has been happening for a while now. The navigation bar isn’t staying on the bottom, and is worse to use it that way, because I’ve been using it for years, and got used to the navigation bar at the bottom. Besides that, it was better this way, as the tabs button was closer to the thumbs, for switching between them.
Brave Version( check About Brave): 1.96.61
Mobile Device details: Xiaomi Poco X3, MIUI 14.0.2
@Problema not seeing this issue on my end. I wager this has to do with the Xiaomi Ui, as we’ve been known to conflict with it before. Let me see if I can get some other team members to test.
Thanks Mattches! I’ve just noticed a different scenario to getting out of full screen, that gives me different results. If I do the steps mentioned before, the “button” with a number inside, that allows you to select between tabs, goes to the top.
But, if I’m playing a video in full screen and I go to another app using the notification that pops up (like a received message, or something like that), the video keeps playing in a small screen (picture-in-picture mode). At that scenario, if I click in the middle of the small video, to expand the window and bring me back to the Brave app, it takes me back to the YouTube tab, not on full screen, and the navigation bar is shown at the bottom.
As soon as I put the video in full screen, and exit like the way mentioned in the topic, it goes back to the top.
It’s like the problem is exiting full screen mode by clicking the arrows that are located at the bottom right of the screen (if looking at the phone horizontally).
Can you show me a screenshot of what it looks like after you exit full screen on youtube (where you see the issue)?
Here is the before and after going into full screen mode: https://imgur.com/a/5xhVnD5
The image with the arrow pointing to the bottom is the “before” image.
And does it stay that way as you continue to browser or visit other sites?
I was able to recreate this issue, but it seems to occur specifically when rotating the phone display from vertical to horizontal. Once this happens, the navigation bar will be moved to the top while viewing vertically and bottom (where it is preferred) while horizontal. The only way to move it back to the bottom of the screen while vertical is to completely close the browser and open it back up. Turning off “auto rotate” on the device does not prevent this from happening.
Samsung Galaxy Note 9
Brave Version: 1.96.61
this happens to me too. samsung galaxy s20 fe, sm-781u. when i go from portrait to landscape it moves. very annoying.
