Hello everyone,
as you can see from the attachment , since brave did the update I no longer get Bat tokens. I made the wallet on Uphold but I don’t understand where it connects from to be able to continue to farm the Bats.
Could you kindly help me.
Thanks everyone =)
Go to brave://rewards, there will be a connect button. Click on that then continue and get options of Uphold / Gemini. Select Uphold enter credentials and you should be able to connect if you’re from a region listed at
