Everything looks okay but if still no show then go to advance and try add the coingecko box ( grass ) it should appear
or if still no then change everyting that you addes to grass or delete it then do the entire process again i couldnt delete for some reason so i just changed those box letters to brass and then added grass to everything again it worked just fine
how much gas fee to transfer grass to bybit?
If you have a friend who has sol its better to take from him cause the transfer rate from wallet to wallet is soo low like cents but still you’ll need at least 0.05 to transfer the sol also to claim it so i suggest get 0.06 from a friend or if you dont have a friend buy atleast 0.09 to safely get back your sol after the claim and transaction
Hey! I tried everything and i still dont see my tokens ![]()
Everything’s here this should do the trick you can dm me in discord we can go in with screen share and all lets see where’s the problem
discord: luchu2332
Hello! How did you manage to display the grass token? Because it doesn’t work for me ![]()
@biglilafun did you do like they instructed?
Köszi, de már inkább váltottam Phantom walletre, abban tökéletesen működik.
Jani
the last guy came to discord i helped him withdraw his stuff also just delete or edit the current one to change the token name and info so you can open new one just in case you need to edit a new one itll work
fiz exatamente como instruíram e msm assim não vejo os tokens Grass, ele aparece, mas está zerado
@jleonard and @onyb I keep seeing some people expressing issues with this. Can you advise if there are any easier ways of handling? In some cases they are saying can add the assets but then seeing 0 balance, which is what diego just above this reply mentioned. While others just seem to have issues even adding the asset.
This is more or less specifically an issue for Grass at the moment.
Same issue here, already activated the token but it says zero grass. i got 17 grass from the first airdrop but it show zero grass.
delete or re edit to change the name and values of grass everything then freshly reopen another one with the values i mentioned above. it’ll work just fine
Did you get any help I have the same problem grass successful added to wallet but won’t display balance is displaying as 0 even thoh I had 64 grass token and grass site said I successfully withdrew my tokens but can’t see them in my wallet. Yes I have sol in the wallet for gas fee
It looks as if the decimals are incorrect. Please try deleting the current GRASS token shown and re-adding with the below info.
Select Network: Solana
Mint Address: Grass7B4RdKfBCjTKgSqnXkqjwiGvQyFbuSCUJr3XXjs
Token Name: Grass
Token Symbol: GRASS
Decimal of precision: 9
edit the current grass to change its names and inside value as these cannot be deleted for some reason idk where the delete btn is
so the trick is edit everything to give it s new coin name and address everything after it saves just
Add nee grass snd it should be good to go
Thanks for pointing this out @Luchu. I’ve raised the issue internally.
Hey I’ve tried that a couple of times no joy. Had to wait a week even as grass wasn’t displaying the withdraw option for the tokens so had to restake them and wait another week as they weren’t transfered to my wallet last despite me signing the transaction and being given the same successful message. So my challenge is now what do I do as it’s about to unlock again and if I Fail to withdraw successfully it seems I have to wait a week before being able to try again. Resetting the info isn’t working the wallet picks up it’s grass when I enter infor and won’t change the settings
