When I’m in the Sync Menu and looking for which devices are in the sync chain, I see that my laptop has multiple entries, around 20-30 to be a bit more specific.
I see those entries on the mentioned laptop itself, but also on my android phone. The entries are different in numbers, though.
- Create a new sync chain
- Add one or more devices to it
- Wait a few days and use it normal
- Look into the sync chain, there are multiple entries from the same device
I believe this situation is the 3rd or 4th time this happens in a timeline of five or six months.
Laptop:
Version 1.69.160 Chromium: 128.0.6613.114 (Official Build) (64-bit)
Android:
Brave 1.69.153, Chromium 12.0.6613.85
Laptop:
Hardware Information:
- Hardware Model: Lenovo ThinkPad X395
- Memory: 16.0 GiB
- Processor: AMD Ryzen™ 7 PRO 3700U w/ Radeon™ Vega Mobile Gfx × 8
- Graphics: AMD Radeon™ Vega 10 Graphics
- Disk Capacity: 2.0 TB
Software Information:
- Firmware Version: R13ET56W(1.30 )
- OS Name: Fedora Linux 40 (Workstation Edition)
- OS Build: (null)
- OS Type: 64-bit
- GNOME Version: 46
- Windowing System: Wayland
- Kernel Version: Linux 6.10.6-200.fc40.x86_64
Android:
- Google Pixel 8 Pro
- 12 GB RAM
- 512 GB Internal storage
Software:
- Android 14
- Android security patch: 5. August 2024
- Vendor security patch: 5. August 2024
Addiional Information:
When I delete the devices with multiple entries, It can happen that I delete the actually used device in the sync chain. No problem so far, I just use the saved sync code in my KeePassXC, but it says the sync code is expired.
Now I found out that the last word, the 25th word, changes every day, and we need to change this, accordantly. This is explained from @Saoiray in his post here and here. I saved now the sync code with the changed new 25th word at the end in my KeePassXC.
Do I need to change this every day, or just when I want to add a new device later?
So this issues is solved with the expired sync code but not with the multiple entries of the same devices. I just want to mention this because maybe it has something to do with this because the situation now is a little different. Now I changed the 25th word, which I did not in the last two or three times of the same situation mentioned above. Perhaps this fixes now, if yes I am going to give feedback here.
