Multi-tasking with "WorkSpaces" and "TabGroups"
Title: Add Opera-style “Workspaces” in Sidebar + Advanced Tab Organization
Feature Request:
I would like to request a Workspaces feature similar to Opera’s, integrated into Brave’s left sidebar (when using left-side tab-organization) or somewhere else if using top-side tab-organization.
In Opera, Workspaces appear as small square icons, each representing its own set of tabs that you can switch between instantly.
In Brave, these could fit perfectly in the left sidebar (for example, in the space highlighted in my attached screenshot) using the same size and style as the current sidebar icon, ensuring the UI remains consistent and modern.
Alongside Workspaces, an advanced tab organization system — for example, the ability to auto-sort tabs, move them between workspaces, or save workspaces as sessions — would make Brave extremely efficient for multitasking.
Why This Should Be Considered:
  • Boosts productivity: Users who juggle work, study, personal, and project-related browsing could switch between isolated “workspaces” instantly without clutter.
  • Keeps Brave competitive: Opera’s Workspaces are a beloved feature. Adding them would attract users who value productivity tools but want Brave’s privacy and performance benefits.
  • Fits Brave’s design language: The sidebar already supports square icons; Workspaces would integrate seamlessly without adding clutter.
  • Enhances user retention: Once users set up their workspaces and workflows in Brave, they’re less likely to switch browsers.
Closing:
If Brave had both Workspaces and strong tab organization tools, I (and likely many others) would happily switch to Brave as my default browser — combining its speed, privacy focus, and modern UI with top-tier productivity features.
Bonus: Opera’s UI is getting very old, its ad-block is not top-notch like Brave, has less compatibility with websites, and it is considerably slow compared to Brave. If Brave had its own multi-tasking features I am certain a LOT of Opera users will switch to Brave, since these short-comings are kind of well known among Opera users, but the Workspaces keep them hooked.
Screenshot attached for sidebar Workspaces placement idea.
I’ve had this feature on my mind since I started using Brave. It exists in Microsoft Edge and it’s super helpful in software development. I like to create workspaces for the repositories I’m working on, then group tabs in those workspaces by pull request. It also keeps personal tabs or research sessions organized and isolated. And for the cherry on top, the workspaces and tab groups persist after browser restarts.
