My Dell Win 10 Pro desktop machine got a Microsoft update, and now will not boot off the C: (boot & apps drive. But, another internal drive still had an older instance of the Win 10 Pro OS on it, and I can boot from it, and pull files off other drives, in this case an “I” drive that was primarily for some programs (apps), and data backup. All the drives, “C:” through “I:”, appear to be working ok, except the OS on “C:” no longer works.
Brave version 1.81.137 was installed on the “I” drive. However, the bookmarks do not display in Brave, any more. The bookmarks and favicons files DO still reside in <Brave…\… …\“Defaults” folder on “I”. I took a look at the bookmarks file, with notepad, being careful not to alter it, and, it looks good, so far as I can tell.
I had just started gradually setting up a new (to me) Dell Win 11 Pro Desktop machine, so I am transferring apps and data to it. Brave version 1.82.166 was added to it a little while back, but only a couple bookmarks had been added to it. Those displayed ok.
I copied the Brave bookmarks and favicons files to a USB flash drive, and then tried to use the import function to move the bookmarks into the Win 11 Pro machine’s <Brave…\… …\”Defaults” folder, and copy / pasted the favicon file there too. (Actually, I’ve tried this both with and without the copy / paste of the favicon file. This appeared to work, but, the imported favorites do not show up in the Brave Favorites bar. I tried copy/pasting over the bookmarks file into that same Defaults folder: Same result.
Please see above.
The bookmarks file and favicons files are in the Win 11 Pro machine’s Brave…\… …\”Defaults” folder, but, Brave does not display them.
I expected to see “Imported Favorites (or bookmarks) displayed in the Favorites Bar.
Always.
Dell Win 10 Pro Desktop machine has Brave version 1.81.137
Dell Win 11 Pro Desktop machine has Brave version 1.82.166
HELP!
