Just sharing, I also have this issue on windows 11 - Brave Version 1.36.119
(https://brave.com/latest/).
The maximize square is grayed out.
A day after I updated to Brave 1.36.119 the problem returned. Not sure if its related to the update or not. Only extension I have is google scholar.
This might help with the debugging. The problem seems to have followed (originated?) into my chrome browser too. I found this website that list the problem: windows 10 - Chrome Maximize button greyed out and not working - Super User
Using somewhat the same method:
- Open Brave
- Enter
brave://flagsin the address bar - Search for “Touch UI Layout”
- Set Touch UI Layout to disabled
I was able to get it to reappear without the reinstall and cleaning.
Thank you so much for your answer. I am using an HP x360 laptop in touch mode and now everything makes sense.
I had the same problem and thought it was an issue with the resolution because I recently changed my laptop’s screen from 720p to 1080p. Turns out, when I change the laptop to “tablet mode” brave automatically changes the UI, which makes some icons bigger, and causes the issue with the maximizing button. Since the icons where bigger, I assumed the UI was rendered in 720p, which happened with other apps because of my old configuration. I never considered it had something to do with the fact that I have a touch screen.
Anyway, I can confirm disabling Touch UI Layout solves the problem. Thanks again.
