Obviously if you spam open a bunch and then look, it’ll use some CPU as it’s still loading things and all.
And what you’re showing isn’t really all the ridiculous. All depends on what you’re doing on each of those tabs. Just because it’s efficiency doesn’t mean it will immediately put everything to 0 resources. It just means it will kind of put them to sleep as resources are needed.
CPU, RAM, etc are there to be used. It’s how you get good performance. It’s worse on devices to constantly pause and activate things. You want it running as long as it’s not overworking. And I doubt based on what you’re showing that anything is really being overworked.
-Side Note-
What you’re showing is OS task manager. You may want to use Brave’s task manager to see what’s going on in particular. You can do this usually by hitting Shift + ESC or you can go to the hamburger menu → more tools → task manager. This will show details such as:
