I can print one browser document in Brave using the system dialog, but if I try to use it again, the feature to invoke the system dialog locks up.
- Bring up a document in Brave
- Select Print (Cmd-P). This brings up Brave’s Print screen. Click on “More settings”. Click on “Print using system dialog”. The system dialog comes up. Click “Print” on the system dialog.
- Bring up a different document in Brave.
- Attempt to print 2nd document (Cmd-P). Brave’s Print screen comes up. Click on “More settings”. Click on “Print using system dialog”.
In my case, this is where the failure occurs. Brave puts a little “swirl” next to “Print using system dialog”, but the system dialog never comes up again. Brave just sits there and waits whenever I try to bring up the system dialog. I can cancel out of Brave’s Print screen. The rest of the browser continues to work fine, but I can’t use the system Print dialog again without quitting out of Brave, and restarting it.
On step #4, I expect that the system print dialog will come up again, and I can select options, and print.
Version 1.40.113
A workaround I use in the meantime is when I get into Brave’s print screen, I click on “More settings”, and then click on “Open PDF in Preview”, and I print from Preview, instead (Cmd-P). This has worked reliably, and does not cause a problem for Brave. It feels like jumping through some hoops, though.
