www.loveotv.com is a page similar to youtube.com …
The problem is very simple … the page loveotv.com does NOT work in brave. Never. It stays charging without stopping. You can’t navigate there at all … after a while, a pop-up window appears that says “The page is not responding” and gives the option to “wait” or exit the page.
The same happens in brave for android.
Try private mode, and the same thing happens.
Disable the extensions and it’s the same.
That you can see the videos and navigate on that page.
1.14.84
