After my work laptop went through “Domain Join / Intune Enrollment” yesterday, Brave is no longer syncing between my work PC and my personal PC even though Brave Sync on each PC lists both PCs.
On my work PC, Sync settings were all “off” - neither “sync everything” nor “customize sync” were selected. Checking “everything” did not change the selections in the data list (all remained off (gray)). Selecting customize and then certain data did not work either - while they turned blue, if I left sync and came back, they were blank.
On my personal PC, everything was turned on in Sync as I originally selected (customized with 3 data checked).
First, I attempted to remove my personal laptop from my work PC’s Brave. Nothing happens. I get the “are you sure you want to delete…?” and I click “ok” and nothing happens at all.
Then I attempted to Leave Sync Chain from my work PC, clicked ok, and no change.
I did the same for my personal PC and both worked - i have no Sync setup on my personal PC now. My intention was to leave the chain on both and try to set it up again. But I’m now stuck because nothing in Sync works on my work PC.
Every time
Same version on both laptops:
Version 1.20.103 Chromium: 88.0.4324.152 (Official Build) (64-bit)
Both devices are Lenovo PCs running Win10
