Key Info Seed: Invalid issue on MacOS - Resolved
Briefly describe your issue:
I recently setup Brave and Brave Rewards. I have setup the browser on 2 Macbook Pros, a Pixel 5 android phone and a Samsung S6 Lite tablet. Everything looks to be working well EXCEPT one of my Macbook Pros. This computer says “Key info seed: Invalid”. This computer is the first one I setup and is the Sync master. I have linked my Gemini account and every thing looks to be setup properly. But I have not received any ads on this macbook pro. I tried uninstalling Brave and reinstalling and nothing looks to have changed.
Here is the info from the brave://rewards-internals/ page;
Wallet payment ID: ------------ (edit: removed after fixing my isses)
Wallet created: 09/04/2021, 12:15:56 PM
MacOS 11.5.1
Brave 1.29.77
Yes
Tennessee
No, but I am new to using Brave and crypto
Are you using a VPN? (yes/no)
No
Yes
n/a
Not sure. I do have auto-contribute off. I initially setup Uphold, but then switched to Gemini when I realized it would be a better fit for me due to Uphold fees.
Thank you
I think I was just able to fix this myself. I went to my Brave Rewards settings page, clicked the gear in the top right corner to open “Manage my Wallet”. Then I reset my wallet. Then I quit Brave and reopened it. Then I turned Brave Ads back on. Then I linked my Gemini account and not my Key Info seed is showing as valid and I’ve already been shown an ad.
Hopefully these steps help someone else later down the road.
