KDE Plasma Desktop-Scaling lets Brave act weird
  1. Latest Nobara Updates (KDE Plasma and any Fedora should work) and Brave Version
  2. In KDE Plasma Display Configuration change the Scaling of a monitor
  3. Move Brave to this monitor
The window size of Brave is when maximized 1) not maximized but acts like it. What I mean is that it only takes 75% of the window (because I set the scale to 75%), but the buttons, even though it doesn’t seem like it, are where they should be. Long story short, the Buttons aren’t where they seem to be, and the window is not the size it should be. 2) Every time I click out of Brave and then in, the window gets smaller
Brave Version( check About Brave): Brave 1.82.172 (Official Build) (64-bit)
Yes, i too have the exact same problem !I have not been able to use Brave Borwser for about 2 months now because of this issue
My KDE INFO:
Operating System: openSUSE Tumbleweed 20251016
KDE Plasma Version: 6.4.5
KDE Frameworks Version: 6.19.0
Qt Version: 6.10.0
Kernel Version: 6.17.2-1-default (64-bit)
Graphics Platform: Wayland
Processors: 12 × 11th Gen Intel® Core™ i5-11500 @ 2.70GHz
Memory: 32 GiB of RAM (31.2 GiB usable)
Graphics Processor: AMD Radeon RX 6600
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: H510M DS2V
Hello Dev(s) are you there ??? - 0 response from you about this issue
Can you please respond ?
