Google sheets functionalities don’t work anymore since today (24/09/2024):
- calendar displaying when double clicking a date
- open multiple link at once (for youtube links)
- preview of an embedded link in a cell not showing
- open the window to resize a column
- certainly more functionalities of the same kind (ones opening new tabs or pop-up window)
- go to any google sheet
- try using any functionality mentioned earlier
- double clicking a date should display a calendar
- when there’s link in several cells, “open links” should open them all at once up to 50
- when hovering a cell with an embedded link, a preview window should open
- column resizing button (in right click) should open said setting in a pop-up window
Current release as of 24/09/2024 at 16:30 CEST
- I’m on Windows 11
- These functionalities do work on Edge where I tested them so it surely comes from Brave and not sheets
- I tried disabling addons and Brave shield, the issue doesn’t come from there either
Edit: Google sheets works just fine again (the 26/09/2024), this post can be closed.
