Description of the issue: My company is uses Salesforce as our CRM. As part of that, we’re pulling in a Domo dashboard to provide dashboarding capabilities within Salesforce. When I navigate to view the Domo dashboards, I see the attached screenshot. When I test this in Chrome, I’m able to see things successfully.
Exact URL of the website in question: https://qualtrics.my.salesforce.com/servlet/servlet.Integration?lid=01r50000000NAb2&ic=1&linkToken=VmpFPSxNakF4T1MweE1DMHhORlF4TlRveE5qb3pNQzR6TnpSYSxhaWpybnY3dHJzUlJZSzc3Um9hSzVOLFlXWmtNR0po
Did the issue present with default Shields settings? (yes/no) Yes
Does the site function as expected when Shields are turned off? No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): Unknown
Does the site work as expected when using Chrome? Yes
Brave version (check About Brave): Version 0.69.132 Chromium: 77.0.3865.90 (Official Build) (64-bit)
