Issue with Linking Existing Wallet - Login Screen Keeps Showing Up
Description of the issue: Cannot link existing wallet to my second device
Is the issue occurring on a specific network? No
What operating system are you using? Android
Brave Version (check About Brave): Brave 1.84.133, Chromium 142.0.7444.53
1 - I’m going to screen where it shows “Browser native. Self-custody. And multi-chain. etc” where you have two options “Need a new wallet?” and “Already have a wallet?”
2 - When I select Already have a wallet, it asks recovery phrases with “Import an existing wallet” and I add all the phrases correctly.
3 - After I click Continue, it asks for me to “Create a password” which I write my password and even allowing fingerprint.
4 - Final page show’s “You’re all set!” and when I click “Go to my portfolio” it says “Double tap screen to continue”, doing that brings me back to screen at step 1.
Expected Behavior: After final page, I would expect to go to my portfolio and use my wallet.
Am I missing something here or is linking the same wallet to another device is forbidden?
If you reinstall the browser do you still see this issue on the second device? Thanks for confirming!
I don’t want to reinstall the browser due to existing data that I don’t want to lose. Is there any other way to fix/test this?
Any other suggestion?
Sorry for the delay. To clarify, do you see the same behavior if you create a brand new wallet, instead of importing?
Hey, yes creating a new wallet is also resulting the same. Is there a way to reset wallet related data without resetting the history/cookies etc?
Edit: Just to be clear, resetting rewards from brave://rewards/ doesn’t work. It just resets already seen ads but issue persists
If you visit Settings –> Brave Wallet –> and Reset and Clear Wallet Data, do you see an improved experience?
This worked! Thanks a lot
It is since ios update.. we have a lot of threads here with this issue. brave wallet not works for month now on newest ios.
