Description of the issue: Googling anything which can result in a “AI Overview“ by google will result in google ai overview’s UI to be glitched, and will show up vertical and horizontal sliders which blocks off a line or two.
Exact URL of the website in question: google.com (any search result with ai overview)
@Synny question is, what settings have you turned on within Google? I get absolutely nothing like you’re showing in terms of Listen or the language selection. Whatever you’re showing is not default on any browser. And I have no idea how to replicate it even if I wanted to.
I’m running default settings, I get these on my other devices too (i want to turn them off but I’m not sure how). I tried this on another browser. I thought this was default. Can you please let me know if there’s an option to disable this?
@Synny What’s weird though is no matter which browser I’m using, I don’t get the translation thing or the Listen button. I tried on Vivaldi, Edge, Chrome, Firefox…all don’t show it.
I don’t know if it’s a regional thing or what? But for now it’s hard to give an example without experiencing it.
@fanboynz are you able to see this? I can’t even get the buttons to appear that they’re talking about. But then I guess where they are saying in Brave when it does appear it is covering up part of the AI overview. So I guess we have the comparison where the one screenshot is what they see when they are in Brave and the other one is what they see whether they’re using the Opera GX
I’m just not quite sure how to even make that appear at this point in time. To be clear they don’t want to hide the AI overview, they just want the listen and translate buttons to not cover up part of the text.
I’m accessing this from India and don’t recall enabling this option. I tried it with other accounts and devices, so I’m fairly certain it’s a region-specific feature, as you mentioned. I also couldn’t find any settings related to AI Overview to change it (I checked the “search labs“ page.)
Yeah I don’t see these controls either when I search. It’s either region specific or there may be some sort of AB testing going on.
I would expect that these controls are very likely to be the cause of the issue. @Synny if you hide these controls via the Block elements feature does this help at all (note that the doc linked is slightly out of date – the Block Elements is now available in the right-click context menu)?
Hi,I am from India.This is the same problem i am facing now,what should i do..i can’t touch it or either remove this thing..it causes so problem,i can’t even read full lines,it covers the whole area..is it a bug or something ??
Hey, so I closed my laptop (i had to go out). I returned and there’s no slider anymore. Not sure how this happened but thanks for the support everyone. Appreciate it!
