- If you have uBlock Origin installed and Brave Shield turned on https://www.carousell.ph/
- If you visit the product listing such as https://www.carousell.ph/search/Playstation%205/
- The ads placeholder box will not be blocked. According to uBO team, it’s because of conflict with Brave Shield.
- https://www.carousell.ph/search/Playstation%205/
- https://www.carousell.ph/p/playstation-5-slim-1355754494/
- Yes
- Yes
Does the ad appear when using a Private window as well? (yes/no)
- Yes
What OS are you using when you see the ad?
- Windows 11 x64
