Is there a way to delete all saved passwords, not individually
@gyanarthi,
Settings --> History --> Clear browsing data --> Advanced, then check the box next to Passwords & Passkeys and change the time range to All time. Once you click Clear data, your passwords will be deleted.
Note that there is no way to undo this action so please ensure that there is nothing you do actually want saved here before doing so.
thank you Matches… it was confusing my password manager, - the manager get jealous sometimes :slight_smile:
appreciate your prompt help
bennett
