Certain versions of iPad and iOS have multitasking capabilities with split screen, with which you can have multiple apps open side-by-side. See https://support.apple.com/en-us/HT207582. This feature can be turned off in iOS settings. However, Safari has special split screen functionality that enables two browser windows to be open at the same time. See https://support.apple.com/en-us/HT207522. Even when the multitasking feature is turned off, this special Safari split screen feature remains on (i.e., cannot be turned off). As a result, when using Brave, you can inadvertently open a link in Safari through split screen.
- On a split-screen compatible iPad device, go to Settings > Home Screen & Dock > Multitasking and toggle off Allow Multiple Apps.
- In landscape orientation, open Brave and navigate to https://www.wikipedia.org
- Press and hold the link for “English” for several seconds until the selected area pops out.
- While continuing to hold the link, drag the link to the left-hand side of the screen until you see the Safari icon appear.
- When you lift up your finger, the link open in Safari.
Either (1) the split-screen functionality is disabled in Brave or (2) the link opens in split screen in another Brave window (rather than a Safari window).
Brave Version( check About Brave): 1.19 (20.07.21.09)
Mobile Device details: iPad mini (5th generation) Model MUQW2LL/A
Additional Information: I realize that I could just avoid activating split screen by not dragging links to the side as described above. However, I’ve found that it is fairly easy to do it by mistake when scrolling through pages quickly and click links. Therefore, I’m not sure that this is technically a bug, but it would be nice if there were a way to disable this so as to minimize the risk of breaking the privacy chain.
