I keep receiving a notification about insufficient funds and pending tips (see screen cap). I guess this is from the time that I had auto-contrib enabled for a time. The rewards screen doesn’t show any of the pending tips, and the amounts are way more than I’m likely to have in BAT in the foreseeable future. Is there any way to expunge this pending tips that I can’t see?
Experiencing the same and not finding any adequate answer for this question.
@discobot seems to go into a flat-spin when asked also
Hi! To find out what I can do, say @discobot display help.
Still an issue for me, I will update here if I learn anything. I hope you’ll do the same.
In my case, I imagine the issue will resolve itself eventually when the 90days of retries rolls around?
Then I’ll just have to avoid using the auto contribute in the future. Still, I feel like there’s a underlying usability/ease of use issue to be resolved here at the very least.
