Installation issue with Ubuntu Mate 20.4
Attempting to install brave on a Raspberry Pi running 64 bit Ubuntu Mate 20.4. followed the script provided and all appeared to work until the last install command when the error “E: Unable to locate package brave-browser” was returned at the system prompt.
I have run the install several times and following the instructions I get the same result every time
1.
2.
3.
Satisfactory installation
Hello @wilwahabri
in my humble knowlegde about rasbperry it use arm am i right ? so maybe that the issue
if you check this page
Brave is only supported on 64-bit AMD/Intel architectures (amd64 / x86_64)
and chrome core does not have arm version yet for linux or windows only for ios/android and recently for mac they release arm based version for the new m1 chip for apple
