@fanboynz @nnm0a @289wk
Okay, so I have noticed some changes/updates regarding this topic.
The “shorts” tab on channel page is now hidden but leaves an empty space/gap.
When clicking on this empty space/gap, the shorts page loads up. Pretty much like a hidden link except you cannot see it. Clicking on the gap loads the channel’s shorts page.
When clicking on these shorts video, they start playing. And then there is an infinite scroll of random youtube shorts, effectively breaking/bypassing the filter.
Other things I also noticed, is that I have Hidden YouTube Comments via “Block YouTube Distracting Elements”. But this does not hide comments in shorts. Comments still loads on shorts. The distracting element filter only works for regular videos.
Essentially, “Block YouTube Shorts” and “Block YouTube Distracting Elements” and “Block YouTube Thumbnails” do not work on shorts. Shorts thumbnails load up, desping having the thumbnail blocking enabled.
A Simple filter to prevent shorts from playing would be to block/blacklist the below 2 URLs in the following format
youtube.com/*/shorts
Where * referes to unique channel IDs. (See image A). Channel IDs generally start with ‘@’ logo. This would eliminate the entire shorts page in content creators channel page.
youtube.com/shorts/*
Where * refers to various unique Shorts urls. (See Image B and C). This would block all shorts from loading.
Image A
Image B
Image C
On asking chatgpt form a resolution
This was its response
Use cosmetic filtering, not DNS filtering, if you want Shorts sections and thumbnails removed while keeping normal YouTube videos.
In Brave’s filter rules, add:
! Hide YouTube Shorts shelves, tabs, buttons, and thumbnails
youtube.com##ytd-rich-section-renderer:has(a[href*="/shorts/"])
youtube.com##ytd-reel-shelf-renderer
youtube.com##ytd-rich-item-renderer:has(a[href*="/shorts/"])
youtube.com##ytd-video-renderer:has(a[href*="/shorts/"])
youtube.com##ytd-grid-video-renderer:has(a[href*="/shorts/"])
youtube.com##ytd-item-section-renderer:has(a[href*="/shorts/"])
youtube.com##ytd-guide-entry-renderer:has(a[href="/shorts"])
youtube.com##ytd-mini-guide-entry-renderer:has(a[href="/shorts"])
youtube.com##a[href^="/shorts/"]
youtube.com##a[href*="/shorts/"] img
youtube.com##img[src*="ytimg.com"]:upward(ytd-rich-item-renderer):has(a[href*="/shorts/"])
Also block direct Shorts URLs:
||youtube.com/shorts/$document
||www.youtube.com/shorts/$document
The first group hides Shorts elements and their thumbnails. The $document rules prevent opening an individual Shorts page.
YouTube changes its markup frequently, so if some Shorts remain, add this broader fallback:
youtube.com##ytd-rich-item-renderer:has([href*="/shorts/"])
youtube.com##ytd-rich-section-renderer:has([href*="/shorts/"])
youtube.com##ytm-rich-section-renderer:has([href*="/shorts/"])
youtube.com##ytm-shorts-lockup-view-model
youtube.com##ytm-reel-shelf-renderer
If your brave version does not support :has() or :upward(), the rules may be ignored. In that case, use the simpler rules below:
youtube.com##ytm-pivot-bar-item-renderer:has(a[href="/shorts"])
Do not add ||i.ytimg.com^ or ||yt3.ggpht.com^ if you want normal YouTube thumbnails to continue working; those domains serve regular video thumbnails as well as Shorts thumbnails.
This was the reponse.
Kindly go through this.
