Increase Bookmark / Toolbar Fonts
Is there any way to increase the Bookmark/Toolbar fonts?
What I an seeing are font size of about 6 or 7.
Just to small for me eyes.
Something like adding a CSS to the Profile.
Thanks in advance for any help.
Brave Version( check About Brave): Version 1.7.98
Windows 10 Pro 1909 fully updated
Hi @browse4ever, Welcome to Community!
Unfortunately there is no way to directly increase the font size of the bookmarks bar. But you can go to brave://settings/appearance and change the font size/style. That will affect almost all text, the bookmarks bar won’t change, but going to brave://bookmarks/, the entries will be bigger.
Thanks for the reply.
It is a shame that the user has no ability to change font size.
Not very user friendly for the elderly even when using a large screen monitor.
actually this is not quite correct , theres a global chrome prefix you can add to your browser shortcut
first input space then this >
/high-dpi-support=1 /force-device-scale-factor=1.3
and All will be well, welcome
@aberrantbank909
Thanks.
That worked.
Do appreciate your help.
no problem, glad i could be of assistance , enjoy
