Checking his hotmail account is impossible since this morning.
- I don’t know.
Expected result: Resolve issue
Version 1.21.76 Chromium: 89.0.4389.86 (Build officiel) (64 bits)
Additional Information: The hourglass runs endlessly. No problem on other browser.
Thanks to help me @steeven
Yo.
@Mysteryo,
I am able to login to my outlook email without any issue. Do you have any extensions installed in the browser at this time? Can you also try logging into your outlook account while using a Private browsing window and see if you get the same results?
Thanks @Mattches, no problem with Tor.
I have just “Google traduction” and “Crypto wallets” in extension. But since the beginning of Brave and no issue before.
EDIT : I turned off both extensions and turned on, solved issue apparently. (tried 3 times to open Hotmail with success) Perhaps comes to Brave update today.
Yo.
@Mysteryo,
Glad you were able to get that resolved. Thank you for confirming.
