Hello everyone,
So i wanted to import everything that I have in Edge to brave, but the problem is when the import window appears it shows only importing favourites
Note that I’m using the last version of edge and brave
I left brave to go to the New Edge browser because of import BS and NO auto baked in language translation in brave. Also settings revert alot when you close the browser…In the future I may come back but for now WAY too many small issues that left me Uninstalling brave. Good Luck.
Thank you for your reply <3 maybe I’ll do the same what you did until they fix all issues
