Description of the issue: Images are not displaying correctly but it’s inconsistant
Tnis is happening on a Window’s PC but running TightVNC as my server and RVNC running on Android as my client.
Something about posting the image corrects the color it does not look the same as a saved file or an active website as it does posted here.
If you don’t know how to use a Remote Desktop it’s beyond the scope of what I’m going to tell you here.
Expected result: Like posted above.
Reproduces how often: Intermittently
Additional Information: Even this post isn’t displaying properly until i upload the screen capture then it get’s correccted or appears corrected prior to posting. I can’t say what happens after I post it.
