I disabled the popup blocker extension, updated the filters and cleared the cache. Unfortunately all those sites still showed a popup.
which popups exactly?
@theJman weird. Do a favor if you can and take screenshots of what you’re seeing on each of those sites. Also, if you can right click and Inspect the ads and show screenshot of what it shows in dev tools it might help to see what it is.
EDIT
Also, @theJman just to show you what I’m encountering on each site, along with my Shields settings, I did a small video. Perhaps I talked too much, but yeah…
Nope, you didn’t talk too much. The video was rather helpful, it shows something different than what I get though (except for Wolverine of course). Speaking of that…
I grabbed what you asked for from Wolverine, along with the same for another site; Magnum Boots (I happened to be looking for a new set of boots that night when I decided to post my original comment so that’s why all the links are to boot company’s). Here are the Inspect images you requested…
Not sure they provide what you’re looking for however, judging by the scroll bars there’s a lot of info hidden from view.
See if this helps.
Will be included in Annoyances and Newsletter lists
Apologies for the late reply, the forum never sent me an email that anyone had responded to this thread.
I tried the website and your fix seems to work. The first time I loaded the page I saw the popup flash on the screen - probably for less than a second - and then it disappeared. I cleared the cache, closed Brave, reopened it and now the popup doesn’t appear at all. Thanks for taking care of that.
