I am trying to figure out where my BAT goes after the month is over. It resets very cycle monthly and the BAT amount just restarts to 0. If I set auto-contribute on in my rewards settings. Does that mean all my earned BAT will go to other contributors? Should I turn off my auto contribute?
Yeah you should, since the number of bat we can get per month has been reduced a lot is very likely that the auto-contribution will give away all your earnings.
If you are using the sync feature you must disable it in all of your devices.
Has a nice day
Thanks John appreciate your inputs!
