I found an old SSD with Ubuntu on it that hasn’t been updated in months, I updated it expected Brave to show the dreaded two icons (one has your profiles, another is a completely blank profile), it didn’t do it. I opened and closed it a few times and searched for it, only one, so I thought there must be something in the configuration to keep it from getting fixed.
What I did:
I backed up the snap/brave folder, nuked it from my computer, (or thought I did)
I found out where the profiles were stored and only copied back everything in that folder, it brought my profiles back, but it showed two icons in the sidebar and now when it shows u twice when I search for it (As if I have two versions of Brave installed, which I don’t).
I’ll nuke everything and set it up like I’m installing it for the first time on a new computer.
Hopefully it works. Maybe it also fix the crashing if I click the icon in the sidebar if I have more then one profile opened at the same time.
Update:
I fixed it so two icons don’t appear when you search for it, making you having to guess which is the correct one, but two appear in the sidebar, anytime it is open, when during the profile select screen, so you have to be careful which one you pin to the sidebar. It still crashes, if you accidentally click on the icon if you have more than one profile open.
Whatever it is, it’s in the brave/current/.config/BraveSoftware/Brave-Browser/
This is where all of your profile and data are stored, and for the time being, you only need to back up that folder.
I will continue to work on it later today or tomorrow.
I’m assuming the blank profile if you click on the wrong icon is the guest profile.
