Yes, that is correct.
Received my BAT for February 2021 already (what I meant by “this month”).
you have 4.735 BATS not 4735 it’s not the same
I have more monthly rewards without spamming.
i also have the same problem
i have the same problem
I’ve not received my BAT token yet. I cannot log in to my publisher account. They are showing 502 Bad Gateway
do you still see those? it seems they fixed it
yes they solved it. i commented 1 days ago.
Thank you for reporting! Please DM with the following information:
- Copy/paste your Wallet ID (found on
brave://rewards-internals) - Your OS and Brave version (first three lines in
brave://version) - A screenshot of your Rewards panel in
Settings --> Brave Rewards.
This will help to speed up the troubleshooting. Thank you in advance!
