I Can't figure out how to "Fireproof" site the way DuckDuckGo does
I’m a newb to Brave Windows browser and after a search of this forum I still can’t figure out how to get the same result as what DuckDuckGo does with their “Fire Proofing” feature. Meaning, I’d like to have Brave save my identity, password and username so I don’t have to manually go through login and two factor authentication. I’ll be trying the same thing on Samsung Android if this works on Windows. Thanks
@threenewfs Make sure that Offer to save passwords & Passkeys and Sign in automatically are enabled in brave://password-manager/settings. Then you can save your login credentials (username/password) for any site the same way you would with any browser by just logging into the site.
It is worth noting that some sites will intentionally log you out after some amount of time for security purposes and you will have to authenticate again.
