How to View Ads on Brave (PC and Mobile)
Please help me figure out which settings I need to enable to see ads on Brave. help me figure out which settings I need to enable to see ads on Brave. Also, do ads appear while watching YouTube?
Ads should not appear on Youtube. If you’re experiencing ads on Youtube, check and confirm your adblock filters are up-to-date. * brave://settings/shields/filters
Clearing cookies/data will help as well. brave://settings/clearBrowserData
If you’re referring to Brave Rewards, you can learn how to connect here: https://support.brave.app/hc/en-us/articles/41704970565261-How-do-I-connect-Brave-Rewards-to-a-self-custody-wallet
Please help me figure out which settings I need to enable to see ads on Brave?
@Kumar01 please read the documentation you were linked to above, as it explains exactly how you can get started using Brave Rewards.
Suppose I am lived in London, and the region setting in my Brave browser is set to the USA; in that case, I will see Brave Ads?
In order to receive relevant ads to you, it’s recommended you set the region in Rewards settings to your actual region.
At this point @Kumar01 I’m going to need you to stop spamming this post on Community. Please refer to the Rewards documentation, which will answer any basic questions about Rewards and how to get started.
