Hi All
I have been looking into Group Policies for Brave browser, so I would not have to manually go through the settings each time a new browser is installed, and set (for example)
- Show autocomplete suggestions in address bar (off)
- Enable Containers (on)
- Speedreader (off)
But unfortunately it seems that not everything that is configurable in brave://settings/ is part of a policy, and some things such as
- Use wide address bar
Cannot be set.
So my question is the following.
Is there a way I can configure Brave Browser, and then export all my changed brave://settings/ and reuse these Settings each time I install Brave?
Thanks in advance
Best regards
