How to no longer accept an insecure LAN connection?
Description of the problem:
When I recently had a certificate error, I unfortunately had to act quickly. That’s why I permanently accepted an insecure connection in Brave.
How can this problem be reproduced?
  1. connect to server without / with invalid certificate
  2. read warning
  3. advanced > continue to [website] (insecure)
Receive warning again when connecting to server without / with invalid certificate.
Brave version (see About Brave):
v1.73.104
Details of the mobile device
Pixedl 7a with Android 15 Build 2025021100 (GrapheneOS)
Additional information:
Specifically, the certificate error occurred in the LAN when accessing the NAS via IP.
Using a Brave Browser New Window, go to brave://settings/shields
DISABLE: Upgrade connections to HTTPS
brave://settings/shields is redirected to chrome://settings/shields and ends with ERR_INVALID_URL. Maybe because I use Brave for Android?
But under Settings > Brave protection and privacy there is Upgrade connection to HTTPS. I can choose there: All connections must use HTTPS, upgrade to HTTPS if possible or do not upgrade connections to HTTPS.
So I should disable HTTPS. And when I reactivate HTTPS, I am asked again whether I trust the site?
Seems strange to me.
Would be my selection. Then test.
