How to disable the right-click translation option?
A couple of days ago, the solution for removing the translation option stopped working. The flag is no longer available.
Does anyone know a current way to remove the translation entry/item?
Here’s how it was solved before (it no longer works):
This option is disabled from me. Turning on and off with restarting the browser did not help.
Just in case, I’ll clarify. I want to remove one item in the menu that opens when the mouse is right-clicked anywhere in the page. In this menu at the beginning of the option - forward, backward, reboot, etc.
They opened this issue one month ago.
https://github.com/brave/brave-browser/issues/46002
But nothing since then.
Thanks! So, we’ll wait for a fix for this obvious bug.
