How to disable built-in torrents
How do I disable the built-in Brave torrent viewer? It was easy enough before, but since the latest update, I can’t seem to figure out where to disable it so that I can use a third party client. All the help I can find online is for the older version.
Hi @martin.demech,
Not yet available. We’ve an issue logged to add the switch which you can track here https://github.com/brave/brave-browser/issues/897
Apologies for the inconvenience.
Thanks
:slightly_smiling_face:
That’s unfortunate, please keep me updated. Thanks!
