Description of the issue: Can’t use Mullvad Leta as the default search engine
- I went into: brave://settings/search, made sure to have “Index other search engines” turned on.
- Once done, I went into to leta.mullvad.net and performed any search on the site
Actual Result :
‘Mullvad Leta’ doesn’t appear under Inactive searches and thus I can’t use it as a default search engine
When going to brave://settings/searchEngines, I should have seen “Mullvad Leta” under Inactive searches and be able to click on the three dots, and make it as the default search engine
MacOs
1.80.115 (Official Build) (arm64)
I’ve tried the same process with StartPage and it works fine, is there a way to also have it for Mullvad Leta?
Sure, I have the option to use their search engine with a keyboard shortcut, but obliviously that’s less straighforward
