If I uncheck “Always Show Toolbar in Full Screen”, the Toolbar/Address bar doesn’t show up when I move my mouse to the top.
Are you using the Compact mode at this time by chance? If so, this is known and we have an open issue to fix this here:
opened 07:55PM - 03 Aug 26 UTC
OS/macOS
QA/Yes
OS/Desktop
full screen
feature/toolbar
### Description
Found while testing https://github.com/brave/brave-browser/issu… es/56914
There are issues when using full screen view (with and without "Always Show Toolbar in Full Screen" enabled) in conjunction with Compact mode for tabs, however the issue observed can vary depending on the state the browser is in when it is launched.
### Steps to reproduce
#### Scenario 1: "Always Show Toolbar in Full Screen" On / Compact Mode Off
Description: "Always Show Toolbar in Full Screen" = On and Compact Mode = Off when browser is launched
1. Clean profile/install of 1.93.131 (can close/relaunch to pull griffin but I don't think it matters)
2. Check macOS application menu (top bar) and make sure View > "Always Show Toolbar in Full Screen" is checked
3. Enable compact mode
4. Go full screen
5. See toolbar is shown as expected
6. Change View > "Always Show Toolbar in Full Screen" to be unchecked
--> toolbar is still shown and it should not be
<details>
https://github.com/user-attachments/assets/d54b3246-d646-43db-8fb7-7168d8eab877
</details>
#### Scenario 2: "Always Show Toolbar in Full Screen" Off / Compact Mode Off
Description: "Always Show Toolbar in Full Screen" = Off and Compact Mode = Off when browser is launched
2. Check macOS application menu (top bar) and uncheck View > "Always Show Toolbar in Full Screen" and relaunch the browser
4. Go full screen
5. Tabs are displayed, but URL bar/Toolbar is not
6. Change View > "Always Show Toolbar in Full Screen" to be checked
--> Same as step 5, tabs are displayed but URL bar/toolbar is not
<details>
https://github.com/user-attachments/assets/30ceb64d-ee08-4eb4-804b-681c06f89508
</details>
#### Scenario 3: "Always Show Toolbar in Full Screen" On / Compact Mode On
Description: "Always Show Toolbar in Full Screen" = On and Compact Mode = On when browser is launched
3. Enable compact mode, relaunch the browser
4. Go full screen
7. Toolbar is not displayed as expected
--> however, if you hover near the top of the screen the toolbar should slide in, but it isn't
<details>
https://github.com/user-attachments/assets/b5cfecfd-5111-49e1-9c23-99fc7db5e36f
</details>
#### Scenario 4: "Always Show Toolbar in Full Screen" Off / Compact Mode On
Description: "Always Show Toolbar in Full Screen" = Off and Compact Mode = On when browser is launched
3. Enable compact mode and relaunch the browser
4. Go full screen
5. Toolbar is not displayed (as expected)
---> Note, you have the same issue as scenario 3, if you hover you don't get the tabs/URL bar
You can continue below if desired, it works as expected:
7. Toolbar displays as expected
<details>
https://github.com/user-attachments/assets/7eeea0bd-6c30-4098-877e-c4e8f7285151
</details>
### Actual result
See above within each scenario
### Expected result
see above within each scenario
### Reproduces how often
Easily reproduced
### Brave version (brave://version info)
Brave | 1.93.131 Chromium: 151.0.7922.71 (Official Build) (arm64)
Revision | db7f09146af1f298c4a422ecc4b6e9f860b8293f
OS | macOS Version 26.6 (Build 25G72)
### Channel information
- [x] release (stable)
- [ ] beta
- [ ] nightly
### Reproducibility
- [ ] with Brave Shields disabled
- [ ] with Brave Rewards disabled
- [ ] in the latest version of Chrome
### Miscellaneous information
cc @rebron @simonhong @kjozwiak
If you’re not using compact mode, I would wager it may be an extension you have installed in the browser that may be conflicting with the functionality.
Yes, I’m using both compact mode and vertical tabs. the bug is in these options. Thanks for responding , and I hope you resolve this issue soon. Good job
