Help with specific site pop-ups
Hi. I’ve been using brave for a number of years and it’s generally very good at blocking ads and pop-ups. However, the pop-up videos on nbcnews.com always appear, and I can’t see anyway of stopping them. I already have my shield set to aggressive, is there anything I can do on Android to stop these infuriating pop-up videos? Thanks very much
@Gmjh
Sounds like you are dealing with a Picture-in-Picture (“PiP”) issue. May interest:
Quickly enter picture-in-picture mode in YouTube
https://brave.com/whats-new/picture-in-picture/
https://github.com/brave/brave-browser/issues/48935
https://github.com/brave/brave-browser/issues/31657
It’s not a picture in picture. It’s a pop-up news stream.
Just tap the X in the top right of the floating video? Or …
You can also use Brave shield’s Block element feature (attached pictures).
Here are the custom filter rules I got after using it, you can try pasting them into your browser custom filters:
  1. Type/paste this in the address bar then enter:
    brave://adblock
  2. Tap Create custom filters, paste these in the text box then tap Save changes
www.nbcnews.com##.jw-wrapper.jw-reset.jw-float-to-top > .jw-media.jw-reset > .jw-video.jw-reset
www.nbcnews.com##.jw-wrapper.jw-reset.jw-float-to-top > .jw-float-bar.jw-reset
www.nbcnews.com##.jw-wrapper.jw-reset.jw-float-to-top > .jw-aspect.jw-reset
Thanks…you’ve solved it for me too!!:folded_hands:
@Mattches
Good work by @leh above.
